Cardio
Dec 05, 2021Follower
internet speed wire router
Hi my internet speed wired is 240 Mbps but wireless, sitting in front of the router it is only 80-100 Mbps. It drops further moving away from the router. The R8000 is only 4 years old. Do you r...
schumaku
Dec 05, 2021Guru - Experienced User
FURRYe38 perfectly fine here - the concern is about the "slow" R8000 .... in reality more about the wireless client causing the problem there. Please consider to change your Bot configuration, or look into your RPA system. No long texts, no full quotes required - waste of bandwidth, time, and display resources only.
Cardio unless you need more coverage by a mesh system, and you intend to update at least the computer you are speed-sensitive, you can keep your R8000 in my honest opinion.
Also meant for additional information in case they wanna reseach more on the MK system.
