Dustin_V
Jan 21, 2020NETGEAR Employee Retired
Introducing the Nighthawk WiFi 6 Mesh System
In case you missed it, NETGEAR introduced its newest product line at CES 2020, the Nighthawk Mesh WiFi system with WiFi 6. NETGEAR’s Nighthawk line of routers has become synonymous w...
Chuck_M
Jan 25, 2020Mentor
What is the difference between this and an Orbi Ax6000 other than the case?
schumaku
Jan 26, 2020Guru - Experienced User
Read fine print and specs.
While the MK62 is a WiFi 6 device, it's AC1800 class "only" - from the tech specs:
AX1800 WiFi 6
- Radio 1: IEEE® 802.11b/g/n/ax 2.4GHz–1024QAM support (600Mbps)
- Radio 2: IEEE® 802.11a/n/ac/ax 5GHz-1024QAM support (1200Mbps)
- Tx/Rx: 2x2 (2.4GHz) + 2x2 (5GHz)
AFAIK the MK62 does not offer a wired backhaul, too. Can't double check because of the user manual isn't available for download.
- schumakuJan 28, 2020Guru - Experienced User
In the part, I was always fighting the "useless" ACnnnn or AXyyyy numbering summing up all radio interface theoretical maximum link rates - here I see that this indication can add some clarity on the product capabilities.
- Jamma00785Feb 03, 2020Star
schumaku wrote:AFAIK the MK62 does not offer a wired backhaul, too. Can't double check because of the user manual isn't available for download.
FWIW, I called support today, and they stated that the MK62 does include Ethernet backhaul. Can anyone confirm that this is the case?- DarrenMFeb 03, 2020Sr. NETGEAR Moderator
That is correct no ethernet backhaul only wireless to the satellite.
DarrenM
Darren- which is correct. That there is not Ethernet Backhaul or there is?
Just wanting to clarify since you stated I was correct and then posted the exact opposite of what support confirmed to me.
- DhgordonJun 30, 2020Aspirant
No wired backhaul are you sure?
- schumakuJul 01, 2020Guru - Experienced User
Dhgordon wrote:No wired backhaul are you sure?
Wired backhaul is supported now - imited to one satellite -> What is an Ethernet backhaul connection and how do I set it up on my Nighthawk Mesh WiFi 6 System?
Unclear in what kind of alternate set-up (e.g. a star or daisy chain via switch(es)) can be made workable.
- Blee1285Jul 01, 2020TutorConfirmed backhaul works with MR60 -> unmanaged switch -> unmanaged switch -> MS60. However this is with only one satellite, I don’t believe a second MS60 can be Ethernet backhauled.
