OksanaT
Aug 27, 2022Follower
Is it possible to separate 2.4 GHz and 5 GHz bands on MR60?
So, I need separated username for 2.4 band and user manual says it possible: To add a WiFi network: 1. Launch a web browser from a computer or mobile device that is connected to your mesh network....
Aug 27, 2022Guru - Experienced User
Try under Advanced Tab/Advacned Setup/Customize WiFI Network
