gsantosoliver
Jul 29, 2021Aspirant
Is it possible to set up R700 as master in a Mesh using the ethernet backhaul with MK62?
Greatings from Brazil, I have a R7000 and I need to extend my wifi. Is it possible to set it up as master in a Mesh configuration with MK62 using the ethernet Backhaul? How can that be set up? ...
Jul 30, 2021Guru - Experienced User
Would it integrate to the system? No.
could it be made to function in addition to the system? Sure.
I'd connect it and go:
R7000----->MR60 (in access point mode)------>satellites
connect the satellites either wired or wireless to the MR60
I'd also set the r7000 with a different ssid and make sure the wireless channels aren't on the same channel between MR60-r7000 to prevent interference
- gsantosoliverJul 30, 2021Aspirant
Would this (r7000 cable to the "MK62 router" and another cable from R7000 to the MK62 "satellite") work or does it need to be a cable from R7000 to MK60 and then from there to the satellite?
How about the wifi? Would the wifi-6 work since r7000 is AC or would the whole wi-fi be limited to AC?- plemansJul 30, 2021Guru - Experienced User
You'd connect the satellite to the MR60 either wired/wireless. Not to the R7000.
The MK60 system would be its own system. seperate from the R7000
