d516430
Aug 10, 2023Aspirant
is it possible to use a MS70 satellite with a MR60 router?
I'd seen in aprevious discussion that the tech people were going to release some software that allowed use of a MS60 satellite with the MR70 router. I wonder if there are any possibilities for the qu...
michaelkenward
Aug 10, 2023Guru - Experienced User
Got a link to that discussion?
- d516430Aug 20, 2023Aspirant
Sorry about the delay!
- Wayno1942001Sep 01, 2023Aspirant
I just noticed I have accidentally bought two new MS70 Satellites and cant connect them with my MR60 as well.
Any extra help on this would be great, have spent hours trying to find out why this wasnt working!
- michaelkenwardSep 02, 2023Guru - Experienced User
Did you follow the link in the message earlier in this discussion? It covers your issue.
Then there is this:
- JudyMVOct 27, 2023AspirantHi, thanks for the link to discussion, but it doesn’t answer the simple question. If you have purchased the MS70 and have a MR60 how on earth do you get it to work? The whole thing is making me crazy with anger that I purchased off NETGEAR specifically chasing a MS60 but got the “better one” that won’t connect 🥺
- michaelkenwardOct 28, 2023Guru - Experienced User
JudyMV wrote:
If you have purchased the MS70 and have a MR60 how on earth do you get it to work?From what I read in those links, you can't get it to work.
Different technologies.
specifically chasing a MS60 but got the “better one” that won’t connect 🥺Methinks that was the first mistake. Going from 60 to 70 does not make the satellite "better".
Have you tried "Ethernet backhaul" with the MS70?
It really is poor of Netgear not to provide the sort of compatibility grid that it has for Orbi devices. If it it exists, I can't find it.
