Captiva
Oct 14, 2022Tutor
Is MS60 WiFi 5 satellite compatiable with MR70 WiFi 6 router?
Greetings, Just replaced my MR60 w/two MS60's WiFi 5 mesh with the MR70 +2 MS70's WiFi 6. This is the MK73S "Costco special" $200 kit. Can the MS60 satellites be configured to work with the ...
rwt75010
Dec 08, 2022Initiate
I am in the same scenario, I have an MR60/MS60system and Costco has the MR70/MS70 system for 200 bucks. I called Netgear support and they assured me they are compatible. I'm in for a try.
- FURRYe38Dec 09, 2022Guru - Experienced User
Let us know how it turns out.
- rwt75010Dec 10, 2022InitiateFirst MR60/MS60 is also wifi 6.
Second “Will the MS60 satellite work with the MR70 router?” Short answer NO!
Long answer “Our engineers are working on a fix which should be ready in the beginning of 2023”.
Hope that helps someone else not spend too many hours squeezing that info from tech support!- Aara22Dec 19, 2022AspirantMy MS60 work fine with the MR70... It's now the MS70s I'm having problems with...
