BrollAmerican
May 24, 2021Guide
Is the AX4300 Mesh compatible?
I have the Nighthawk Mesh 6 system and then the router started losing connection with the modem. After some testing, I determined the modem was fine, so the issue was with the router. I went to Cost...
May 24, 2021Guru - Experienced User
What actual mesh system did you have?
The RAX isn't a mesh router. So it doen't integrate with the full mesh systems.
It can be use in conjunction to them but not integrateed.
BrollAmerican
May 24, 2021Guide
I have the MK63-100NAS Mesh system. The router portion seems shot, but are the satellites usable with the RAX45 router?
- michaelkenwardMay 25, 2021Guru - Experienced User
BrollAmerican wrote:
I have the MK63-100NAS Mesh system. The router portion seems shot....
What does that mean? What have you tried to fix it?
What is the modem in front of it?
...but are the satellites usable with the RAX45 router?
Unlikely, but that's a question best asked in the right place.
- plemansMay 25, 2021Guru - Experienced User
BrollAmerican wrote:I have the MK63-100NAS Mesh system. The router portion seems shot, but are the satellites usable with the RAX45 router?
No. the satellites need the MR60 router to connect to. They won't connect to the RAX45
