BrollAmerican
May 24, 2021Guide
Is the AX4300 Mesh compatible?
I have the Nighthawk Mesh 6 system and then the router started losing connection with the modem. After some testing, I determined the modem was fine, so the issue was with the router. I went to Cost...
BrollAmerican
May 24, 2021Guide
I have the MK63-100NAS Mesh system. The router portion seems shot, but are the satellites usable with the RAX45 router?
michaelkenward
May 25, 2021Guru - Experienced User
BrollAmerican wrote:
I have the MK63-100NAS Mesh system. The router portion seems shot....
What does that mean? What have you tried to fix it?
What is the modem in front of it?
...but are the satellites usable with the RAX45 router?
Unlikely, but that's a question best asked in the right place.
