markris85's avatar
markris85
Follower
Sep 02, 2022
Is the MR60 backward compatible with the EX6120 and/or EX6100v2?
I upgraded my home wifi network to the MR60 and satellite MS60 Nighthawk Mesh wifi-6. It so far works great with much-improved data rates and coverage.  I'm sitting here with two AC extenders, the EX...
  • FURRYe38's avatar
    Sep 02, 2022
    I presume they should work in a pinch.
    Best to keep wifi sources to a minimum as there can be too much wifi signal in the home that can cause problems:
    https://youtu.be/UR0viMLISz4
    Would use the NH app or a wifi laptop that can connect to the EX setup web page as well.
    Review the online user manual and installation guides here:
    https://www.netgear.com/support/
