Bruce49
Feb 18, 2022Tutor
Is there a reason to not change my router SSID and Network Key? (Nighthawk MR60)
A few days ago my mesh router (MR60) stopped working. Netgear Support assisted me in updating the firmware. During the process of getting the router working again the Tech told me not to change the r...
- Feb 19, 2022
I prefer to make changes through the router login. But either should work.
You should be able to change it. the techs usually just have people setup stuff in default configuration to prevent something the users is doing from being the issue.
Feb 19, 2022Guru - Experienced User
- Bruce49Feb 19, 2022Tutor
Thank you!
