Bruce49's avatar
Bruce49
Tutor
Feb 18, 2022
Is there a reason to not change my router SSID and Network Key? (Nighthawk MR60)
A few days ago my mesh router (MR60) stopped working. Netgear Support assisted me in updating the firmware. During the process of getting the router working again the Tech told me not to change the r...
  • plemans's avatar
    Feb 19, 2022
    I prefer to make changes through the router login. But either should work.
    You should be able to change it. the techs usually just have people setup stuff in default configuration to prevent something the users is doing from being the issue.
