Network_Eng
Mar 07, 2022Aspirant
Isolate LAN and WLAN connections
Hello, I have a need to isolate LAN and WLAN traffic and keep some devices from the meaty core of my home network. I can use Guest to isolate WLAN clients that are prone to hacking and have vulnerab...
Mar 07, 2022Guru - Experienced User
Something that the MK mesh system doesn't support. If your looking for more ways to separate some devices and have this kind of feature, you may want to look in to the Orbi Pro series MESH system. The MK series is more designed for the average home user with easy of setup and use.
