Retired_Member
Jan 10, 2021Isolate regular and guest WiFi MK62/MR60
The MK62 - MR60 router needs a way to properly separate the regular WiFi from the Guest WiFi to properly secure IoT and private network. At least I have not found this feature in any of the settins....
Mattse
Feb 10, 2021Guide
I did a test by changing in to Router-Mode (a lot of cable connect/disconnect :-) ) - the effect is the same and the issues with the guest network are identical to the issues in AP-Mode
Retired_Member
Feb 17, 2021netgear would it be possible to get an official statement --
are there plans to make this a feature of the MK6x series? Is it not planned? Are we missing something? Do we all need to purchase a separate wifi and managed switch to fully separate wifi networks?
I think its a very straight forward solution that you could offer here and would help many others.
Thank you.
D
