SunnyApache
Nov 20, 2022Aspirant
Issue: Can't Connect Unmanaged Switch to MR60
Have read all past discussions about this but couldn't find a confirmed solution. Here are my hardware: Cable Modem: MT7711 24X8 Cable Modem Two unmanaged switches: Trendnet TEG-S80g Netgea...
- Nov 21, 2022
The MT7711 is a modem/router combo device. And going router----router causes a double nat unless setup properly.
IT doesn't always cause issues but when it does, then you need to fix the double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
Nov 20, 2022Guru - Experienced User
What is the Brand of the Internet Service Providers modem/ONT the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router and switch. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and swtich been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I currently have my MK63 (router mode, v.132) set up behind my CAX80 cable modem, though it's in router mode so i'm double NAT'd. The MR is connected to my GS108, also a GS308 works. LAN port #8 on the GS switch is used from the LAN Port on the MR. This wired PC is connected to LAN port #1 on the GS108. I also have my MS ethernet net connected to the GS as well. Both are synced and running fine.
