SunnyApache's avatar
SunnyApache
Issue: Can't Connect Unmanaged Switch to MR60
Have read all past discussions about this but couldn't find a confirmed solution.   Here are my hardware: Cable Modem: MT7711 24X8 Cable Modem Two unmanaged switches: Trendnet TEG-S80g  Netgea...
  • plemans's avatar
    Nov 21, 2022
    The MT7711 is a modem/router combo device. And going router----router causes a double nat unless setup properly.
    IT doesn't always cause issues but when it does, then you need to fix the double nat.
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
