SunnyApache
Nov 20, 2022Aspirant
Issue: Can't Connect Unmanaged Switch to MR60
Have read all past discussions about this but couldn't find a confirmed solution. Here are my hardware: Cable Modem: MT7711 24X8 Cable Modem Two unmanaged switches: Trendnet TEG-S80g Netgea...
- Nov 21, 2022
The MT7711 is a modem/router combo device. And going router----router causes a double nat unless setup properly.
IT doesn't always cause issues but when it does, then you need to fix the double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
Nov 22, 2022Guru - Experienced User
Any updates on this?
Mines working going on over 2 days with a GS-108 switch connected behind the MR.
- Trendnet TEG-S80g
- Netgear ProSafe GS108
The cable modem has 4 LAN ports. MR60 is connected to one of the ports. All WIFI device connected to MR60 network work well.
MR60 firmware version: V1.1.7.132_2.0.64
When I connect switches to the cable modem LAN ports, wired connections are good. But when I connect the switch to the Ethernet port of MR60, no wired connection can be established.
Is there any step or configuration change I should take? TIA.
