soysoy
Jan 26, 2021Tutor
Laptop wont see wifi network, but everything else does
So i just set up the system. and after set up, i turned off the wifi on my bell homehub 3000, and changed the wifi name and pass to the same as the Bell wifi was, so all my devices could connect aga...
Jan 26, 2021Guru - Experienced User
Look it up in the device manager. Then get the driver from intel
soysoy
Jan 26, 2021Tutor
that was EXACTLY the right info! thanks plemans!
steps:
device manager isnt easy to find to be honest, if you right click the windows logo, you get a search option, in which you can type device manager, or you can right click on "this pc" in windows explorer and select properties. from there you have device manager as a selectable on the top left.
once device manager pops, go down to network adaptors and open tree, make note of wireless adaptor, then googled, and quickly found the Download page, which for me was intel dual band wireless-AC 7265
thanks again plemans!
- plemansJan 26, 2021Guru - Experienced UserGlad it worked!
