Ultrabikeman's avatar
Ultrabikeman
Follower
Nov 20, 2022
LED Remote Lighting Interence with MS60 Satellite Connection
I installed 2 LED overhead lights that have a remote control. When I plug the lights in it seems to interfere with connecting 2 of my 3 MS60 satellites which are connected to my MR60 Router. If I unplug the lights I can reset the satellites and it seems to connect again. Is it possible these lights or remotes are preventing the connection?  Is there a work around so I can use everything together?
  • FURRYe38's avatar
    Since some IoT devices have a broadcast, They are known to be a source of interferences. Keep them far apart from the MR and MS as possible...
  • plemans's avatar
    Not sure as I don't have that system but can you change the 2.4ghz channel (take it off auto) and the 5ghz channel? Maybe its creating interference and changing the channel can help with that.
