Jeffrey54
Jun 17, 2021Follower
Lennox iComfort Cannot connect to Network since switching to MR 60 Mesh
 I recently installed the MR 60 Mesh network.  I have had no connection problems until I tried to access my Lennox iComfort thermostat via the mobile ap.  I checked the therostat and it shows it is no...
schumaku
Jun 24, 2021Guru - Experienced User
Talk to that other vendor again. The MR60/MS60 system has a 2.4 GHz wireless on air. Possible problems are discovery apps requiring the mobile on a 2.4 GHz connection (for no reason - everything connects to the same logical network), or a wireless clients strugling about the AX mode also active on the 2.4 GHz.
Not sure if the MR60/MS60 system allows to disable the AX mode on the 2.4 GHz band (something like Advanced.->Setup -> Wireless Network uncheck AX mode for 2.4Ghz). This often helps to associate poor IoT WiFi clients.
