BEHART's avatar
BEHART
Losing ability to connect to MR60
Just recently, I have been losing connection to my MR60 router and 2 satellites. It just says connection failed. I usually end up having to set it up again, which is a pain. Now I am having issues just being able to connect to the router. I don't know what's the issue. It's happening a lot.
  • plemans's avatar
    1. what modem/gateway is it connected to?
    2. what firmware is on the router and satellites?
    3. what actually happens? Does it connect but say "connected, no internet" ? does the wifi stop broadcasting entirely? Does it broadcast but you can't connect?
  • I am using firmware 1.1.7.132. It's connected to an AT&T router. I did finally get it to work again. I feel like I have to try everything a couple times before something makes it work.
    I eventually unplugged everything. I don't know what made it work. I reset then unplugged the AT&T router and netgear mesh router and ran through all the prompts and it still wouldn't connect. It just wouldn't connect to the mesh router. I tried to log into the mesh router through a wired connection and going to routerlogin.net, but it couldn't be found. I walked away defeated. When I came back it finally had the login screen, and once I logged in, everything started connecting again.
