Lenelmira
Oct 06, 2021Follower
Maximum distance MK63 ax1800
I am thinking of purchasing an MK63 ax1800, While my house is only a little over 2000 square feet, I hav two shops, one 150 feet from the house and the second 300 feet from the hours (but 150 feet fr...
Oct 06, 2021Guru - Experienced User
Not supported. Too far.
Couple of options would be to runn a CAT6A LAN cable from the main router building out to these two remote buildings, or possible try a
https://www.netgear.com/business/products/wireless/wireless-airbridge/wbc502.aspx
Solution for connecting long distances.
