kayton
Jan 27, 2021Aspirant
Maximum number of satellites for AX1800 (MK64)
What is maximum number of satellites for AX1800 (MK64)? thank you.
I haven't seen any official list on this like there is with Orbi. Any idea Christian_R ?
- Christian_RNETGEAR Employee Retired
Hello kayton,
We recommend up to 3 satellites but we have received positive feedback from others that they've been able to add more.
Christian
With the nighthawk being dual band, what performance penalties do you take with the satellites past that 3-4 devices.
And with it being dual band, is it limited when daisy chaining them because of the performance hit?
- kaytonAspirant
I am trying to cover a 7000 square foot house, very spread out. We need WiFi6. Should I use Orbi or Nighthawk? There are internal cinderblock walls so I will need lots of nodes. What do you recommend? What is the max number of nodes and max number of daisy-chains that you recommend
7000sqft is a large home. And cinderblocks do an amazing job of blocking wifi. (literally one of the best materials at blocking wifi)
You're best option would be to find a way to hardwire in the satellites either using ethernet, powerline, or moca adapters (ethernet over coax). If you could hardwire them in, then a dual band system would be fine because they'd have a hardwired backhaul.
But if its not an option, I'd at minimum be looking at the triband orbi's. They have a dedicated wireless backhaul. Again, the cinderblock is still going to impede that a bit but its going to tolerate it better than a dual band system.
