jakecarroll
Apr 17, 2020Aspirant
MESH D7800 and R8000
Hi, I just purchased a D7800 modem router and have now just purchased a X6 AC3200 R8000 modem. I am wanting to set up the R8000 as a wireless access point running like a mesh system so I can get on...
Apr 17, 2020Guru - Experienced User
That's because neither device is a mesh. You can't expect to buy non-mesh devices and just "be able to run them mesh".
You can set the same ssid for their wireless signals but it isn't going to roam the same as an actual mesh network. And it can create issues as both have smart connection/band steering.
I'd recommend running them with band steering on and using 2 different ssid'. 1 ssid for each.
jakecarroll
Will connecting a AX6000 to my D7800 allow me to mesh & roam seamlessly?
- plemansApr 17, 2020Guru - Experienced User
AX6000 is a speed. Not a device.
Which device are you refering to?
- jakecarrollApr 17, 2020AspirantNetgear Nighthawk AX6000 8-Stream WiFi 6 Mesh Extender (EAX80-100AUS)
It should.
Something to keep in mind even with wireless mesh extenders is that they work great with 1x of them. If you're needing more than 1 extender, its best to go with a full mesh system like orbi.
