eits1986's avatar
Aug 01, 2022
Mesh MR60 + Satellites: Inconsistent/Poor Connection
Currently paying for 960 Gb uploads, speed test through nighthawk app/router yields between 500/600 Mb up, 50 down. Will go days with no interruptions connected to mesh (speeds of 150-170 Mb up), the...
  • plemans's avatar
    Aug 02, 2022
    you mean the modem is in modem only mode?
    If so, go to 192.168.100.1
    the router side is disabled so its ip address won't work.
    If it was me?
    I'd go c6900 (router mode)---->MK60 (ap mode)
    I'd have the c6900 with its own ssid and on a different channels to prevent interference. Then device close it it could use it for data offloading while the MK system covered the peripheral.
    In terms of performance on the MK system, check the base router. You should be able to hit gigabit speeds over a wired connection. And get fairly decent 5gh speeds from it. The satellites won't have the same performance.
    I'd take a read through DongKnows review on it as he does a great job doing testing/overviews on setups without being affiliated with any of them. It'll give you some performance numbers of what to expect that I can't because I don't have the system to test with .
    https://dongknows.com/netgear-mk63-nighthawk-review/
