petercreate
Oct 25, 2022Tutor
Mesh Mr60 router doesn't work and cannot be updated with the firmware
Hi, I've tried reset and other reset methods I can find. Also, I tried the method introduced here, https://kb.netgear.com/000064624/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-on-Apple-...
- Oct 25, 2022
Glad you got it figured out 🙂
Might mark it solved so others aren't still trying to fix it
Oct 25, 2022Guru - Experienced User
what firmware version are you on?
Is the router working and it just won't update its firmware?
petercreate
Oct 25, 2022Tutor
Hi Plemans, thank you for your reply. It's working well now after a successful updating the firmware. Previously I connected the router via its Internet sock instead of the Ethernet sock, which was the reason the updating didn't work.
- plemansOct 25, 2022Guru - Experienced User
- petercreateOct 25, 2022Tutor
Thank you. Don't know where to mark it, just sending a kudo with your message.
- FURRYe38Oct 26, 2022Guru - Experienced User
