petercreate
Oct 25, 2022Tutor
Mesh Mr60 router doesn't work and cannot be updated with the firmware
Hi, I've tried reset and other reset methods I can find. Also, I tried the method introduced here, https://kb.netgear.com/000064624/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-on-Apple-...
- Oct 25, 2022
Glad you got it figured out 🙂
Might mark it solved so others aren't still trying to fix it
petercreate
Oct 25, 2022Tutor
Hi Plemans, thank you for your reply. It's working well now after a successful updating the firmware. Previously I connected the router via its Internet sock instead of the Ethernet sock, which was the reason the updating didn't work.
Oct 25, 2022Guru - Experienced User
- petercreateOct 25, 2022Tutor
Thank you. Don't know where to mark it, just sending a kudo with your message.
- FURRYe38Oct 26, 2022Guru - Experienced User
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router- petercreateOct 26, 2022Tutor
Thank FURRYe38. Have that done. 🙂
