aha71's avatar
aha71
Follower
Mar 10, 2024
Mesh router for 1gb fibernet connection
Hi
I have 1Gb fibernet connection with an effective speed of 800Mb down and 900Mb up (tested). I get around 400Mb  with my current Nighthawk or Nokia SurerWifi tested on Apple Macbook Pro M2 Pro or Iphone 14.
Which mesh router would you recommend when I want to take full advantage of a 1 Gbps fiber optic connection?
regards
Anders
  • FURRYe38's avatar
    What model MESH router do you have? MK?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • michaelkenward's avatar
    michaelkenward
    Tested how? Wifi?
    What are you doing that needs a connection at 1 Gbps?
