gusanchez10
Jul 16, 2021Aspirant
Mesh system for my home
Hello, I have aquired the nighthawk x4 extender. However I did not know any of the mesh function until I received the package. I want to make a mesh system for my home. I am assuming I need to chang...
Jul 17, 2021Guru - Experienced User
The EX7300 is a mesh extender. It works with pretty much all routers (theres a couple verizon ones that cause issues).
So what router do you have?
Are you needing more extenders or why are you thinking you need a different router?
- gusanchez10Jul 21, 2021Aspirant
I have a acrux 1200 nexxt router, I want to have my own mesh system around my home, I already have mesh netgear router.
- michaelkenwardJul 22, 2021Guru - Experienced User
Which one?
What's that? Are you using it as well as a Netgear router?
If so beware this:
What is Double NAT? | Answer | NETGEAR Support
- gusanchez10Jul 25, 2021Aspirant
No, I do not have a netgear router, that was a typo,
https://www.nexxtsolutions.com/connectivity/internal-products/ARL02124U1, this is the router I am currently using.
In addition, I am using a netgear extender. (Nighthawk X4 AC2200 Model#EX3700).
What I am looking for is a good mesh system for my home, using the netgear extender since I already have it.
So, I probably need to change my nexxt router to a better netgear router with mesh function.
So I was wondering if you could recommend me a good router(s) to make my own mesh system in my place.
