akoz
Jun 26, 2024Tutor
Mesh System Won't Broadcast SSID during setup.
Hi! Any help is appreciated. Router: CAX30 Mesh System: MK63S Internet works fine from the router, but across the house where my desktop is, it's awful, hence the mesh system. But after power...
Jun 27, 2024Guru - Experienced User
Try this. Disconnect the MK system from the CAX. Reset the MK system again by pushing and holding reset for up to 15 seconds while powered on. Then during the install of the MK system, connect a pc/laptop to it for setup. After going through setup (use a different ssid from CAX), make sure to put it in access point mode and have the wifi on different channels from the MK system to the CAX system. Once that's done and its in AP mode, then hardwire it into the CAX
- akozJun 27, 2024Tutor
Thanks so much for the reply. None of the devices I own have an Ethernet port. Any workaround for that?
I have hard reset the mesh, plugged it into the router, but when I go to routerlogin.net, there is nothing about setting up a mesh system. I've searched in every nook and cranny.
- plemansJun 28, 2024Guru - Experienced User
disconnect the MK63 from the CAX. when its connected, its in a double nat with 2x routers running. the 2nd one needs to be in access point mode. So disconnect i from the cax, try using the routerlogin or its IP address then. go through setup and put it in AP mode before connecting it to the CAX.
- akozJun 28, 2024TutorIf I disconnect it from the CAX it still is just in set up mode. Neither of the satellites ever sync with it. They try but they time out and have amber lights for a bit. Also, if I disconnect them from the CAX, there is no SSID and so I'm connected to nothing and routerlogin.net just times out, you know?
Anyway I am just going to return and try the TP link Deco. I appreciate you trying to help so I'll send the kudos ♡ thank you
