akoz
Jun 26, 2024Tutor
Mesh System Won't Broadcast SSID during setup.
Hi! Any help is appreciated. Router: CAX30 Mesh System: MK63S Internet works fine from the router, but across the house where my desktop is, it's awful, hence the mesh system. But after power...
akoz
Jun 27, 2024Tutor
I have hard reset the mesh, plugged it into the router, but when I go to routerlogin.net, there is nothing about setting up a mesh system. I've searched in every nook and cranny.
Jun 28, 2024Guru - Experienced User
disconnect the MK63 from the CAX. when its connected, its in a double nat with 2x routers running. the 2nd one needs to be in access point mode. So disconnect i from the cax, try using the routerlogin or its IP address then. go through setup and put it in AP mode before connecting it to the CAX.
- akozJun 28, 2024TutorIf I disconnect it from the CAX it still is just in set up mode. Neither of the satellites ever sync with it. They try but they time out and have amber lights for a bit. Also, if I disconnect them from the CAX, there is no SSID and so I'm connected to nothing and routerlogin.net just times out, you know?
Anyway I am just going to return and try the TP link Deco. I appreciate you trying to help so I'll send the kudos ♡ thank you- plemansJun 29, 2024Guru - Experienced User
akoz wrote:
If I disconnect it (the mr60?) from the CAX it still is just in set up mode (not sure exactly what you mean by this, screensnips might help) . Neither of the satellites ever sync with it (they'll only sync with the mr router, not the cax). They try but they time out and have amber lights for a bit. Also, if I disconnect them from the CAX, there is no SSID and so I'm connected to nothing and routerlogin.net just times out, you know?----factory reset the MR router, hardwire the satellites into it. when its rebooting, connect to the MR system and use the browser based installation. once set, then switch it to AP mode and hardwire the MR into the CAX
Anyway I am just going to return and try the TP link Deco.-----I think you'd do better to get a modem only device and connect the MR system to it or a deco system do it, Running 2x routers puts you in a double nat and causes issues. Its what you've been battling the whole time. I appreciate you trying to help so I'll send the kudos ♡ thank you
