atomsk100
Oct 24, 2022Aspirant
Mesh Wifi 6 after power outage
yeah I have the same problem in Northern california where the power company turns off the power everytime its windy. For a router with zero physical power button to be unable to recover from a disrup...
Oct 24, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Just did a simulated power outage for 1 minute with my MR and after I powered it back ON, got internet services. It's using latest FW v.132 currently.
- atomsk100Oct 24, 2022Aspirantinteresting that fw version is newer than mine. I'd like to update and rule that out, but everytime i check for updates its said my version is the latest. the firmware has never updated
- FURRYe38Oct 24, 2022Guru - Experienced User
Thats ok. Sometimes NG doesn't push FW via the auto update feature. Mine didn't see this either. It's ok to manually update though:
