atomsk100
Oct 24, 2022Aspirant
Mesh Wifi 6 after power outage
yeah I have the same problem in Northern california where the power company turns off the power everytime its windy. For a router with zero physical power button to be unable to recover from a disrup...
Oct 24, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Just did a simulated power outage for 1 minute with my MR and after I powered it back ON, got internet services. It's using latest FW v.132 currently.
atomsk100
interesting that fw version is newer than mine. I'd like to update and rule that out, but everytime i check for updates its said my version is the latest. the firmware has never updated
- FURRYe38Oct 24, 2022Guru - Experienced User
Thats ok. Sometimes NG doesn't push FW via the auto update feature. Mine didn't see this either. It's ok to manually update though:
