CmdrSolo
Jun 25, 2021Follower
Mesh WiFi 6 Router(MR60) & L2TP VPN via Synology
Just bought and installed the Mesh WiFi 6 Router(MR60) and am trying to configure the port forwarding for L2TP VPN service to my Synology Server. I believe I have the 3 ports configured correctly (50...
Christian_R
Jun 30, 2021NETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
