Starzoneca
Feb 05, 2021Tutor
Mesh WiFi 6 System (MK62) - MS60 lan connection connect to your hardwire network connect
I am looking to purchase this Nighthawk® Mesh WiFi 6 System (MK62) and was wondering if I can connect the MS60 Nighthawk Mesh WiFi 6 Satellite to my internal hardwire network which I hardwire to different areas of my home back to central switch and will it use that connection to communicate with the router or will it travel over WiFi signal to communicate?
Or
Is that LAN port on MS60 only for external device likes, a game console, computer or TV that dont have wifi built in?
the MK62 system supports a wired backhaul and can perform much better in that configuration.
plemans wrote:the MK62 system supports a wired backhaul and can perform much better in that configuration.
One more Question regarding the ethernet Backhaul. Does it matter if goes through a switch? Will it impact all the other hardwire connections?- plemansGuru - Experienced User
Some have said there's issues with green switches and some managed switches (running igmp).
I haven't had any issues and i've used several green switches and a netgear managed one.
