Geener13
Sep 19, 2022Follower
Mesh WiFi 6 System Setup
I am attempting to set up my new MeshWifi 6 System AX1800 and it says it’s an invalid QR code so I attempted manually using the preset login and password but it says it doesn’t find that network. I did connect the router to our modem which went fine. Now what?
What mesh system is it? (hint, ax1800 is a model)
What modem/gateway are you connecting it to?
If its a new purchase, you get 90 days of free support to help with setup. sometimes is a faster option.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
