macka601
Mar 22, 2025Aspirant
Mk60 satellite ethernet ports usage?
Hi there I have a question about the ethernet port on the back of the mk60 satellites, Are they just passing packets from the wifi side to the wired or can you use these as access points in their ow...
michaelkenward
Mar 22, 2025Guru - Experienced User
macka601 wrote:
Are they just passing packets from the wifi side to the wired or can you use these as access points in their own right?
Not sure what you mean by that, but the LAN ports are LAN connections to the network.
The LAN ports on the MS30 satellites can be used for wired backhaul to the MR30 and/or as LAN ports for anything else that you plug into them.
Disclaimer: Just another user with time on their hands.
