FergDavidson
Oct 30, 2023Aspirant
MK62 — Nighthawk Mesh WiFi 6 System - WIFI SPEED SLOW
I used this mesh system with Spectrum 200mbs package and got nearly the same wifi speed as wired. I've just updated my ISP to TDS 600 max and the wired connection gets 600+ both down and up. WIFI ...
Oct 31, 2023Guru - Experienced User
You might get a bit faster speeds connected to the router but not the satellites. Reason why is the dual band systems don't have the dedicated backhaul of the tribands to maintain throughput.
Dong Knows has a pretty solid review on the MK60 set.
Netgear MK63 Review: Lacking but Reliable | Dong Knows Tech
Worth the read and a look at the satellite speed versus the router speed.
