nmcant
Aug 06, 2020Guide
MK62 - Unable to connect wifi printer using 802.11b/g
Last night, I try to connect my old HP wifi printer to the home network established by MK62. The SSID can be found using the printer but unable to connect to the home network.
My old HP printer support 802.11b/g with WPA2-TKIP/AES. I config my MK62 using WPA2 but the printer still unable to connect to the home network.
Anyone got the experience using old wifi products but with difficulties in connection to MK62? Thanks.
(p.s. I raised the query to Netgear Support. They asked me to disable the function "AX" to tackle the problem. I buy MK62 beacuse it is using wifi 6 and compatible with old wifi standard. I am so confused that why I need to buy wifi 6 routers with disabled "AX")
- Christian_RNETGEAR Employee Retired
Hello nmcant,
Thanks for sharing your feedback. I recommend continuing to work with our support team regarding your issue.
Christian
- nmcantGuide
Hi Christian,
Thanks for your reply. I received the reply from your colleague in supporting team today. He requested me to seek for technical support from HP on the setting to mesh router network if needed. I am so angry that how come a technical support can provide a substandard reply like this.
First, from my understanding, "Compatible with 802.11a/b/g/n/ac" means old devices with old wifi standard can be used with MK62. My HP printer can work properly with my old ASUS and Linksys routers using 802.11b/g. If problem in connection with old wifi standard exists, I believe it has been raised out and resolved. But now the problem arised obviously was due to compatibility problem with MK62, how come he requested me to seek for technical support from HP??? Second, my HP printer bought 7 years ago. Will HP still provide technical support to me? Similarly do Netgear technical support still work on a 7 year-old model? I don't think so!!! Third, my HP printer is a obsolete product with at least 7 years old. Do you think mesh router network exists at that moment? What a big joke!!!
I understand my case is now handled by supporting team but it deemed not willing to resolve. So would you please try to help? Thank you.
Anthony
nmcant wrote:First, from my understanding, "Compatible with 802.11a/b/g/n/ac" means old devices with old wifi standard can be used with MK62. My HP printer can work properly with my old ASUS and Linksys routers using 802.11b/g. If problem in connection with old wifi standard exists, I believe it has been raised out and resolved. But now the problem arised obviously was due to compatibility problem with MK62, how come he requested me to seek for technical support from HP?
Anthony,
There can be wireless clients struggling to connect when a wireless station like a router/access point is showing AX (Wi-Fi 6) on-air. Popular example were for example many different Intel chip based wireless adapters which refused to connect to Wi-Fi 6 systems. Typical short term workaround was to disable the AX (Wi-Fi 6) capability, long term solution was and is updating the wireless drivers (typically including firmware for the wireless adapter embedded system) on the base OS.
Not much Netgear or other Wi-Fi 6 vendors were able to do....
-Kurt
