dondale
Apr 13, 2020Aspirant
MK62 adding more satellites?
Hello, Is it possible to add additional satellites to the MK62 Nighthawk Mesh system? I've looked around, and it doesn't appear that the satellite is sold separately. Is it possible to configure ...
dondale
Apr 15, 2020Aspirant
Thanks so much, Christian! As a followup question: Is it possible to connect all three satellites to the router via Ethernet, through a switch?
Thanks again for your time and attention.
Christian_R
Apr 15, 2020NETGEAR Employee Retired
Happy to help, dondale! And yes, both should work.
Christian
- Enrique407Apr 16, 2020Aspirant
Hi,
if i buy 2 Mk62 systems, am i able to use the second router as a Satelite ? and have a total of 3 satelites in the network.
