dondale
Apr 13, 2020Aspirant
MK62 adding more satellites?
Hello, Is it possible to add additional satellites to the MK62 Nighthawk Mesh system? I've looked around, and it doesn't appear that the satellite is sold separately. Is it possible to configure ...
iamck
Dec 18, 2020Guide
Hey
I’m trying to do the exact same thing? Has anyone instructions on how to do this? I can’t figure it out at all?
I have it connected over cable to the original router (as it fails the add satellite sync thing) so I can get it an ip 10.0.0.28 but I can’t log into it to set it as an access point which I assume is what I need to do?
I finally got the second satellite working after 30 tries but just need the router as the third!
Any help very much appreciated.
Chrismerch
Jan 02, 2021Initiate
Access point is not the same, it doesn’t join the mesh network and I am forced to change the WiFi name. This needs to be fixed, how is it possible that this isn’t supported. It’s such a basic concept and it can rectified with an update. The MR60 should have Router Mode and Satellite mode. Can someone offer insight if there will be new firmware that can resolve this? It’s almost $500 worth of hardware that I’ll be forced to return to the store in exchange for something that doesn’t restrict this such as Eeros. It’s clear that I’m not the only person with this issue :(
