DiggyDid
Mar 16, 2023Aspirant
MK62 Custom/Default SSIDs
Hello, I have a Nighthawk Mesh MK62 that I just set up a few days ago. Firmware is up-to-date as of this posting. I like to split my 2.4/5GHz networks to avoid down-performing due to slower...
Mar 16, 2023Guru - Experienced User
What do you mean by default SSID being broadcast? The one from the MR at initial setup is being seen on mobile devices?
Did you set a custom SSID name for the main SSID before configuring the custom SSID name?
DiggyDid wrote:
Hello,
I like to split my 2.4/5GHz networks to avoid down-performing due to slower devices. I was able to create 2 custom SSIDs (one for each band), and disabled SSID broadcast. However, the default SSID was still broadcasting. As a workaround, I changed it to a dummy SSID and used an insanely difficult password to prevent unauthorized access, but I would prefer to disable that SSID entirely.
Is it possible to disable this default SSID entirely (not just disable broadcast)? It seems that there are 4 possible SSIDs able to be broadcast - Default (2.4/5GHz), Custom 2.4, Custom 5, and Guest (I assume this is dual band as well). The app has very limited functionality, and the web interface is less intuitive.
Helpful answers are greatly appreciated.
Condescending or hostile replies will be flagged. Let's try to keep it friendly.
DiggyDid
Edit (underlined italics):
FURRYe38 By default, I mean the factory default SSID. I left this alone until I could set up my own SSIDs. In order to disable my SSID broadcast, I had to enable the "Customize WiFi Network" option to set up the SSIDs I defined. However, that factory default SSID was still broadcasting. I changed this after setting up my own SSIDs. There's no option to disable - broadcast or otherwise - from the Wireless Settings tab. I changed it as I usually do when first securing the router.
Does that answer your question?
- FURRYe38Mar 16, 2023Guru - Experienced User
Yes.
Looks like the main SSID can't be disabled. Checking mine, i see main SSID and the two custom SSIDs broadcasting. No options to disable the main as I presume that is intended.
- DiggyDidMar 16, 2023Aspirant
That's exactly what I'm seeing, so at least I'm not alone. It's not a huge deal, and I'm confident it's secure, I've just learned from experience if it's not being used, don't put it out there.
Thanks for you help!
Ya I get it. I presume that the main reason is that most users have the main running and only use the custom section on a limited basis. The main is whats most used and most common. Thus no need to disable it and probably not allowed to at the FW and chip level. There has to be a signal for the MS to connect too and the MS rely on the mains to be in good working order.
Enjoy. 📡
