Duddydud
Aug 27, 2022Follower
MK62 How do I make 2.4 and 5ghz separate?
Hello, Just set up my MK62 mesh system, and I can't locate the 'customize wifi setting' all the directions speak of to separate the 2.4 from the 5 channel. Anyone know if this is possible?
Aug 28, 2022Guru - Experienced User
the 80 series had that option originally and I'm pretty sure it was rolled out to the 60 series you have in firmware updates. (so make sure your firmware is current if you're wanting to do this)
The KB article doesn't show the 60 series but it should work if you follow this guide.
