Pincushion79
Oct 23, 2020Aspirant
Mk62 wifi devices
I keep seeing the mk62 being marketed as being able to support 25+ wifi devices. What is the "+"? I have 45-50 devices and my current nighthawk x8 continuously drops them at random. Please tell me how...
microchip8
Oct 23, 2020Master
NETGEAR routers usually support up to 32 devices per band. You're overloading your router with so many devices connected at it
Pincushion79
The x8 is triband, even with combining the 2 5ghz bands, it should still support 64 devices. Not sure how that would be overloading my current router.
- microchip8Oct 24, 2020Master
Combining bands doesn't make it send out some magical superband.
- Pincushion79Oct 24, 2020AspirantYour words, 32 per band. If I were to use all 3 bands... 96... if I were to use only 2, 64 devices. But I am around 45 or so and still having issues.
Pincushion79 wrote:
Your words, 32 per band. If I were to use all 3 bands... 96... if I were to use only 2, 64 devices. But I am around 45 or so and still having issues.Assuming your devices are spread across the different bands. For example, if all of them are on the 5 GHz band, if you exceed the limit, your router will start to choke. Also combining bands is done for speed not for how many more you can connect to the combined band
