mattdeluca
Mar 28, 2022Guide
MK63 daisy chain and star network layout
Hello all,
I'm having some connectivity issues with one of my satellites on MK63, although the light is blue, when I'm connected to this satellite, the speed is very slow, almost non-existent. When I'm in range of other satellite and router, the speed is fine so I'm assuming it's a weak backhaul connection??
I found this page What is daisy chain and how does it work with my Orbi WiFi System or Nighthawk Mesh System? | Answer | NETGEAR Support
and my actual configuration seem to match the second diagram (star config) so I'm wondering if my router is setup to run as a daisy chain but where it's physically in the form of a star config, maybe it's trying to backhaul to the other satellite that's further away than the router? if that makes sense, hence the weak satellite.
Is there an option to change the configuration settings from daisy chain to star and vice versa? I have looked through the GUI and can't see anything that relates to it or is it an automatic thing? It's frustrating and I'm considering hardwiring it to the router.
Thanks in advance
Matt
hardwired is the way to go if you have that option. with the dual band mesh systems it has to use the same network to communicate router---satellites as it does satellites---devices. That cause a significant speed reduction (around 50%). If you're hardwired in, you don't take that speed hit and your latency is lower. That's why the tribands with their dedicated wireless backhaul perform so much better than the dual band mesh systems. but hardwired, the dual bands perform pretty much the same.
there used to be a setting so you could disable daisy chain and force star topology.
It was removed a while ago.
so you're kind of stuck with letting it auto-negotiate.
A few things you can try.
Change locations. Sometimes a lateral move can help as much as moving closer because things in the walls (think hvac, etc) can be blocking signals.
Also, try hardwiring a pc/laptop into the satellite for testing other locations. that way you know you're actually testing the backhaul versus the fronthaul.
I'd also advise trying to swap the satellite with other satellites to see if its actually a location issue or that specific satellite issue.
Thanks for the reply plemans, I thought that may be the case, I have a couple of days off work coming up so I will swap the two satellites to see if it's a location issue or a satellite issue but I have a feeling it's got a weak backhaul to the other satellite instead going direct to the router which is located in between the two satellites. Worse case scenario I will hardwire it to the router as it's only about 15m give or take from the router.
Matt- plemansGuru - Experienced User
