Lynster141
Oct 30, 2022Aspirant
MK63 Loss of config after unplugging power for less than 1 minute
2nd day of using the MK63 system... seems to work very well. I moved the power adapter from a non-protected outlet to my UPS Battery system. It was unplugged for less than a minute. After the ro...
mnzs-blen
Oct 31, 2022Aspirant
Losing thee setting is a big NO and it doesn’t as well even for me as well. You might experience the amber light if in case satellite is placed near to dead zone.
How do you define satellite 🛰️ lost setting ? Any reference or screenshot to it please ?
Lynster141
Mnzs-blen,
Hey, I never said the Sats lost config. Just the router node. In fact, they both had Blue led's after the router node went off to never land. However, once I reset the router node to factory settings, both satellite nodes went Amber.
All is up and working right now, but it was very concerning that this occurred after moving the power adapter.
Thanks for your input.
- FURRYe38Oct 31, 2022Guru - Experienced User
