IanW76
Jul 28, 2020Follower
MK63 Mesh - Ethernet Switch Connection
Need to confirm that the MK63 nighthawk mesh can be connected via an ethernet switch. Plan is to use in AP mode and connect to existing ISP router. Also plan/need to connect the mesh units via the ex...
plink53
Jun 05, 2021Aspirant
Have similar question. Bought the MK63 mesh hoping I could use wired ethernet for the backhaul but it doesn't appear that the satellites can use this. It appears the ethernet port is for local wired connection to the mesh. Is this correct?
