Cinji18
Oct 09, 2023Aspirant
MK63: Not getting Internet connection even thought the indicator light is solid blue
MK63 (AX1800) The router has a solid blue light, but I am not getting any Internet connection on any devices.
Oct 09, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many MS are deployed?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- Cinji18Oct 09, 2023AspirantHow do I find out firmware version?
Both the modem and the router were turned off all night, then turned back on this morning.- Cinji18Oct 09, 2023AspirantModem is a Motorola DOCSIS 3.1
- michaelkenwardOct 09, 2023Guru - Experienced User
Cinji18 wrote:
Modem is a Motorola DOCSIS 3.1That tells us the make (Motorola ) and the Internet technology (DOCSIS 3.1). It doesn't tell us which model it is.
Motorola has made quite a few different DOCSIS 3.1modems over the years.
Cinji18 wrote:
How do I find out firmware version?That's not likely to be the reason why it doesn't work, but you can read about these things by looking at the support pages for the MK63.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. - FURRYe38Oct 09, 2023Guru - Experienced User
Are you leaving the ISP modem and MK system OFF every day or was this a one time that you had turned everything OFF? They should be left ON 24/7.
Both the modem and the router were turned off all night, then turned back on this morning.- Cinji18Oct 09, 2023AspirantIt's usually on 24/7, but my dad said it started acting up last night, so he turned everything off after I went to bed. It's still not working after I woke up.
