Cinji18
Oct 09, 2023Aspirant
MK63: Not getting Internet connection even thought the indicator light is solid blue
MK63 (AX1800) The router has a solid blue light, but I am not getting any Internet connection on any devices.
Cinji18
How do I find out firmware version?
Both the modem and the router were turned off all night, then turned back on this morning.
Cinji18
Modem is a Motorola DOCSIS 3.1
- michaelkenwardOct 09, 2023Guru - Experienced User
Cinji18 wrote:
Modem is a Motorola DOCSIS 3.1That tells us the make (Motorola ) and the Internet technology (DOCSIS 3.1). It doesn't tell us which model it is.
Motorola has made quite a few different DOCSIS 3.1modems over the years.
- Cinji18Oct 09, 2023AspirantMotorola MB8611
- FURRYe38Oct 09, 2023Guru - Experienced User
You can find the FW version on the MRs web page. 192.168.1.1
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
