Cinji18
Oct 09, 2023Aspirant
MK63: Not getting Internet connection even thought the indicator light is solid blue
MK63 (AX1800) The router has a solid blue light, but I am not getting any Internet connection on any devices.
michaelkenward
Oct 09, 2023Guru - Experienced User
Before diving off into arcane territory, start simple and tell people a bit more. I'm afraid things like "it doesn't work" provide few diagnostic clues.
Are these wired or wifi connections?
What happens when you try to connect? Any error messages?
Can wifi clients see the SSID broadcasts from the MR60 and/or MS60?
What modem, ONT, gateway sits between the MR60 and the Internet?
- Cinji18Oct 09, 2023AspirantI'm not sure where the error messages are showing up. I just know my devices say no Internet or their lights are telling me they are not connecting.
What is SSID? What is MR60 or MS60?- FURRYe38Oct 09, 2023Guru - Experienced User
SSID is the wifi service ID name of the wifi broadcast that comes from the MR and MS satellites.
MR is the router base unit, MS are the remote satellite units.
