araghava
Apr 28, 2020Star
MK63 question
I just installed MK 63. When I look at the system by logging in from my desktop I correctly see 2 satellites. 1 wired and 1 wireless. However the app on my iPhone says there is only one sattelite...
Christian_R
May 01, 2020NETGEAR Employee Retired
Hello araghava,
May you login into the router's admin page using a web browser. Please refer to page 85 of the user manual to view and confirm the devices attached to your network. Can you check to see if both satellites are included on the list.
http://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf
Christian
araghava
May 01, 2020Star
HI Christian,
Thanks for responding. Yes, when I login from my desktop it shows 1 wired and 1 wireless.
However the iPhone app only shows one satellite. As I mentioned in my post when I go to the network map in the iPhone app it shows 1` attelite with a green dot and then a dotted line to another satellite with a pink dot. What does the dotted line mean and what does the pink dot mean.
- Christian_RMay 01, 2020NETGEAR Employee Retired
Hi araghava,
May you let me know the current app version your phone is on (iOS or Android).
Thanks,
Christian
- araghavaMay 01, 2020Star
IPhone: 2.4.24.1
